installing gazebo_ros_pkgs for groovy
today i tried to reinstall gazebo and gazebo_ros_pkgs following the current instructions. Gazebo compiles and runs without any problems. but when i tried to compile gazebo_ros_pkgs I ran into a couple of problems.
1st missing shared objects in the precompiled ubuntu package
when I called catkin_make to compile the gazebo_ros_pkgs there where at least one missing .so file:
/usr/bin/ld: cannot find -lgazebo_sdf_interface
so i tried compiling from src witch leaded to other problems
2nd rosdep installs gazebo-prerelease
the command rosdep install --from-paths src --ignore-src --rosdistro groovy -y installs
gazebo-prerelease and sdformat debian packages.
this should probably not happen... but can be easily undone, with apt-get remove...
3rd when I try to run catkin_make I get an error about redefinition of classes.
In file included from /usr/local/include/gazebo-1.9/gazebo/sdf/interface/SDF.hh:25:0, from /usr/local/include/gazebo-1.9/gazebo/sdf/sdf.hh:21, from /usr/local/include/gazebo-1.9/gazebo/physics/State.hh:26, from /usr/local/include/gazebo-1.9/gazebo/physics/ModelState.hh:30, from /usr/local/include/gazebo-1.9/gazebo/physics/Model.hh:31, from /usr/local/include/gazebo-1.9/gazebo/physics/Actor.hh:24, from /usr/local/include/gazebo-1.9/gazebo/physics/physics.hh:2, from /home/bbrieber/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/include/gazebo_plugins/gazebo_ros_block_laser.h:37, from /home/bbrieber/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_block_laser.cpp:26: /usr/local/include/gazebo-1.9/gazebo/sdf/interface/Param.hh:50:9: error: redefinition of ‘class sdf::Param’ /usr/include/sdf-1.4/sdf/Param.hh:52:9: error: previous definition of ‘class sdf::Param’
currently I don't know how to fix this problems. I would be happy if some one could point me in the right direction...
Thx
Benjamin
In file included from /usr/local/include/gazebo-1.9/gazebo/sdf/interface/SDF.hh:25:0, from /usr/local/include/gazebo-1.9/gazebo/sdf/sdf.hh:21, from /usr/local/include/gazebo-1.9/gazebo/physics/State.hh:26, from /usr/local/include/gazebo-1.9/gazebo/physics/ModelState.hh:30, from /usr/local/include/gazebo-1.9/gazebo/physics/Model.hh:31, from /usr/local/include/gazebo-1.9/gazebo/physics/Actor.hh:24, from /usr/local/include/gazebo-1.9/gazebo/physics/physics.hh:2, from /home/bbrieber/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/include/gazebo_plugins/gazebo_ros_block_laser.h:37, from /home/bbrieber/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_block_laser.cpp:26: $HOME/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/include/gazebo_plugins/gazebo_ros_block_laser.h:37, from $HOME/catkin_ws/src/gazebo_ros_pkgs/gazebo_plugins/src/gazebo_ros_block_laser.cpp:26: /usr/local/include/gazebo-1.9/gazebo/sdf/interface/Param.hh:50:9: error: redefinition of ‘class sdf::Param’ /usr/include/sdf-1.4/sdf/Param.hh:52:9: error: previous definition of ‘class sdf::Param’
Thx
Benjamin
