Hi all,
I am making an smoke animation in blender 2.5 using its particle system. Currently i am using ros electric on ubuntu 10.04 and simulator_gazebo stack.
My ist question is whether it is possible to import that animation correctly in simulator_gazebo? if not then migrating to gazebo_ros_pkgs with Hydro or Groovy will help me to achieve this objective?
Second, Is there any other good approach to achieve this functionality for example simulating particles inside simulator_gazebo without using any other models(.dae, .stl) etc?
Last, I will prefer some solution sticking to same distro of ros but can migrate too.
Thanks alot.
(P.S detailed answer will be appreciated since my conceptual grasp on the topic is very less and limited)
