How to bypass the ros-gazebo rosmake/makefile magic?
Is there some documentation about how to build Gazebo for ROS after trying to apply some patches? I do need bumper sensors, which are still broken in 1.6.16 on Gazebo for ROS Fuerte.
The known patch was promised for 1.6.17, but this has not been released (as of 02/Oct/2012)...
A normal rosbuild either does nothing, or first downloads and then unpacks the "magic" tarballs with ROS-compatible Gazebo checkouts, which in turn overwrites any patches applied to the source tree...
Is the following correct?
1 install ros-fuerte-simulator-gazebo package
2 remove any existing ROS_NOBUILD 3 rosmake --pre-clean
(which downloads the magic tarball, unpacks, compiles everything) 4 cd to the actual gazebo source tree 5 edit some source files, apply patches, etc. 6 make 7 make install 8 cd to simulator_gazebo; touch ROS_NOBUILD
I am (trying to) use Gazebo on ROS Fuerte with the Shadow hand model. The latest available release version is 1.6.12, with
  1. install ros-fuerte-simulator-gazebo package
    2
  2. remove any existing ROS_NOBUILD 3 ROS_NOBUILD
  3. rosmake --pre-clean
    (which downloads the magic tarball, unpacks, compiles everything) 4 everything)
  4. cd to the actual gazebo source tree 5 tree
  5. edit some source files, apply patches, etc. 6 make 7 etc.
  6. make
  7. make install 8 install
  8. cd to simulator_gazebo; touch ROS_NOBUILD
