gazebo crashes immediately using roslaunch after installing gazebo ros packages
after installing everything properly I am following the tutorials to test the tools (using groovy, gazebo 1.9 and gazebo_ros_pkgs). I have a problem using roslaunch to start gazebo following this tutorial
http://gazebosim.org/wiki/Tutorials/1.9/Using_roslaunch_Files_to_Spawn_Models
when I want to start with command roslaunch gazebo_ros willowgarage_world.launch gazebo crashes after one sec and I get this error:
[gazebo_gui-3] process has died [pid 15649, exit code 139, cmd /home/usr/catkin_ws/src/gazebo_ros_pkgs/gazebo_ros/scripts/gzclient __name:=gazebo_gui __log:=/home/shahed/.ros/log/8981441a-03ea-11e3-8d2b-0017c4a8146b/gazebo_gui-3.log]. log file: /home/usr/.ros/log/8981441a-03ea-11e3-8d2b-0017c4a8146b/gazebo_gui-3*.log
this problem happens with all world files( mud_world.launch, shapes_world.launch, rubble_world.launch), except the empty and willowgarage_world, both of them can be started using roslaunch tool but not always from the first attempt. Mostly from the second try.
I also followed “Creating a Custom World File” in the same tutorial and still the same problem occurred.
Any help plz!
Thanks in advance.
click to hide/show revision 2
None
Any help plz!
Thanks in advance.
