libbullet not installed
I'm attempting to do a manual install of a lower version of gazebo for a specific work environment.
Since I was working on a blank Ubuntu OS that never had gazebo installed. I first used sudo apt-get install gazebo,then sudo apt-get remove gazebo to keep the dependencies, but not the up-to-date version.
However, when I try to install the package I want, it goes like this:
sudo dpkg -i gazebo_1.7.3-1~precise_amd64.deb Selecting previously unselected package gazebo. (Reading database ... 188459 files and directories currently installed.) Unpacking gazebo (from gazebo_1.7.3-1~precise_amd64.deb) ... dpkg: dependency problems prevent configuration of gazebo: gazebo depends on libbullet; however: Package libbullet is not installed. dpkg: error processing gazebo (--install): dependency problems - leaving unconfigured Processing triggers for desktop-file-utils ... Processing triggers for bamfdaemon ... Rebuilding /usr/share/applications/bamf.index... Processing triggers for gnome-menus ... Errors were encountered while processing: gazebo
Apparently, there is still one dependency that wasn't added. How do I go about installing libbullet?
