Set intensity for an object so gazebo_ros_laser will notice
Hey, I'm very new to ros and gazebo.
I'm trying to make the gazebo_ros_laser notice a reflecting Object. But when I check this->parent_ray_sensor_->GetLaserShape()->GetRetro(ja) in the gazebo_ros_laser.cpp it is set to zero.
in my urdf file i set the laser retro value to 200
    <robot name="reflector">
  <link name="test_reflector">
      <origin xyz="5 5 2" />
      <mass value="1.0" />
      <inertia  ixx="0.0" ixy="0.0"  ixz="0.0"  iyy="0.0"  iyz="0.0"  izz="0.0" />
    <visual>
      <origin xyz="5 5 2"/>
        <box size="1 1 2" />
      <material name="Cyan">
    <color rgba="0 1.0 1.0 1.0"/>
      <laserRetro>200.0</laserRetro>
    <collision>
 <gazebo reference="test_reflector">
    <material>Gazebo/Grey</material>
    <laserRetro>200</laserRetro>
could you please tell me what I'm doing wrong?
Also I would really like to know how the information I specified in the urdf-file finally gets to the class RayShape. Should this not happen somewhere in urdf2gazebo.cpp?
Thanks for your help
    <visual>
    <collision>
I'm trying to make the gazebo_ros_laser notice a reflecting Object. But when I check this->parent_ray_sensor_->GetLaserShape()->GetRetro(ja) this->parent_ray_sensor_->GetLaserShape()->GetRetro(ja) in the gazebo_ros_laser.cpp gazebo_ros_laser.cpp it is set to zero.
    <visual>
    <collision>
