Error 141: libgazebo_ros_control can not be found in Gazebo 2.0.0
When running my simulation using Gazebo 2.0.0, I get the following non-critical error:
Error [Plugin.hh:141] Failed to load plugin libgazebo_ros_control.so:
libgazebo_ros_control.so: cannot open shared object file: No such file or directory
I don't use the ROS control part of the simulation for now, so it doesn't matter too much. However, I thought I should mention it here. I think that the current ros-hydro-gazebo-ros-control package might still be linked against Gazebo 1.9.
