Gazebo 1.9 Failed to load Plugin even with exporting $GAZEBO_PLUGIN_PATH
I am currently doing the model manipulation plugin tutorial.
I was able to do the World Control tutorial with no problems.
But on this tutorial I am getting:
Error [Plugin.hh:127] Failed to load plugin build/libmodel_push.so: build/libmodel_push.so: cannot open shared object file: No such file or directory
I have correctly exported the directory with export GAZEBO\_PLUGIN\_PATH=*path to build dir*:$GAZEBO\_PLUGIN\_PATH and checked.
I checked previous similar questions but they all seem to say to export the directory. In this case the directory is exported but I am getting the same error.
click to hide/show revision 2
No.2 Revision
Error [Plugin.hh:127] Failed to load plugin build/libmodel_push.so: build/libmodel_push.so: cannot open shared object file: No such file or directorydirectory
 export GAZEBO\_PLUGIN\_PATH=*path to build dir*:$GAZEBO\_PLUGIN\_PATHdir*:$GAZEBO\_PLUGIN\_PATH
and checked.
