How to attach arm to a static base using SDF
I have been playing around with building my own robotic arm. It's very simple and I have all of the joints working. I was hoping work with the arm in a zero gravity environment so movement was easier. The problem I run into however is that the base will always float off or be affected by the arm rotation. I want to fix the base to the ground.
I have tried the following without success:
<sdf version="1.4"> <model name="full_robot_arm"> <include> <uri>model://robot_arm</uri> <pose>0.0 0 1.0 0 0 0</pose> </include>
  <uri>model://arm_base</uri>
  <pose>0 0 0 0 0 0</pose>
<joint name="fixed to ground" type="revolute">
  <parent>ground_plane::link</parent>
  <child>robot_arm_base::body</child>
   <axis>
    <limit>
      <lower>0</lower>
      <upper>0</upper>
    </limit>
    <xyz>0 0 1</xyz>
    </axis>
<joint name="shoulder_joint" type="revolute">
  <parent>robot_arm_base::body</parent>
  <child>robot_arm::shoulder_rotator</child>
  <axis>
    <xyz>0 0 1</xyz>
  </axis>
</model> </sdf>
It does attach the arm to 'a' ground plane but this will rotation along with the rest of the body.
<?xml version='1.0'?>
<sdf version="1.4">
version='1.4'>
    <axis>
     <limit>
       <lower>0</lower>
       <upper>0</upper>
     </limit>
     <xyz>0 0 1</xyz>
     </axis>
   <axis>
     <xyz>0 0 1</xyz>
   </axis>
</model> </sdf>
