some basic questions - mobile robot
Hi! I spent last month struggling with Ubuntu, ROS, Gazebo etc. an I'm still having some questions totally obvious for you, but can save me lot of time. What I need to do is a 2-wheel mobile platform using Hokuyo laser to build his map. I'd appreciate if anyone tell me the easiest way to do it. I tried using ros_control but got some problems with the packge. Now I'm trying to build one gazebo model plugin subscribing to Hokuyo's topic and managing joint velocity. Still, I don't know: 1. How could it then orientate in space to build a map. Is Gazebo providing something like the global coordinates frame or current position of a robot? 2. In a plugin, I've thought of using a joint object in the way like here:
namespace gazebo { class SetJoints : public ModelPlugin { public: SetJoints() : ModelPlugin() {
public: void Load(physics::ModelPtr _model, sdf::ElementPtr _sdf)
                                //left_wheel_hinge is my name for the joint in model.sdf file
 this->leftJoint = physics::Base.getByName("left_wheel_hinge");
public: void OnUpdate(const common::UpdateInfo & _info)
leftJoint->setVelocity(1,1)
private: physics::Joint *leftJoint;
}; GZ_REGISTER_MODEL_PLUGIN(SetJoints) }
Code does not work because of getByName function. Is there any way to use joint object in the plugin? Thanks for any help
Hi! I spent last month struggling with Ubuntu, ROS, Gazebo etc. an I'm still having some questions totally obvious for you, but can save me lot of time. What I need to do is a 2-wheel mobile platform using Hokuyo laser to build his map. I'd appreciate if anyone tell me the easiest way to do it. I tried using ros_control but got some problems with the packge. Now I'm trying to build one gazebo model plugin subscribing to Hokuyo's topic and managing joint velocity. Still, I don't know: 1. know:
some basic questions - mobile robot& joint velocity
