Hello, I am trying to build a sdf model of a differential drive, but I am having some issues. The problems are caused by the caster wheel joint.
Here is the sdf code:
<link name="caster_wheel"> <pose>0.045 0 -0.0528 0 -0 0</pose> <gravity>1</gravity> <self_collide>0</self_collide> <kinematic>0</kinematic> <inertial> <mass>0.01</mass> <inertia> <ixx>0</ixx> <ixy>0</ixy> <ixy>0</ixy> <iyy>0</iyy> <iyz>0</iyz> <izz>0</izz> </inertia> </inertial>
<collision name="caster_wheel_geom">
<laser_retro>0</laser_retro>
<sphere>
<radius>0.01</radius>
</sphere>
<surface>
<friction>
<ode>
<mu>0.01</mu>
<mu2>0.01</mu2>
<fdir1> 0 0 0</fdir1>
<slip1>0</slip1>
<slip2>0</slip2>
</ode>
</friction>
<bounce>
<threshold>100000</threshold>
</bounce>
<contact>
<ode>
<soft_cfm>0</soft_cfm>
<soft_erp>0.2</soft_erp>
<kp>1000000000000</kp>
<kd>1</kd>
<max_vel>100</max_vel>
<min_depth>0.001</min_depth>
</ode>
</contact>
</surface>
<visual name="caster_wheel_geom_visual">
<pose> 0 0 0 0 -0 0</pose>
<sphere>
</sphere>
<script>
<name>Gazebo/Yellow</name>
</script>
<joint name="caster_joint" type="revolute"> <pose>0 0 0 0 -0 0</pose> <parent>chassis_link</parent> <child>caster_wheel</child> <axis> <xyz>0 1 0</xyz> <dynamics> <damping>0</damping> <friction>0</friction> </dynamics> <limit> <lower>-10000000000000000</lower> <upper>10000000000000000</upper> <effort>0</effort> <velocity>0</velocity> </limit> </axis> </joint>
before starting the simulation, everything looks normal:
the caster wheel is the front yellow sphere. Right after clicking on the play button of gazebo, here is what happens:
I tried to understand what is wrong, but I can't see any problem.
Thank you
Andrea
