How does one use /gazebo/spawn_sdf_model ?
I'm trying to delete and respawn an SDF model as a (hopeful) work around to my problem here.
I'd like to use a rosservice so I can call it using a rospy.ServiceProxy.
For now, I'm just trying to get it to run from the command line:
$ rosservice call /gazebo/spawn_sdf_model "model_name: 'joe'
model_xml: '/home/benb/Dropbox/RoboticsResearch/WAMInProgress/tp/AllInOne/Trajectory_Phonebook/ros_stuff/src/iiim_wam_description/wam.sdf'
robot_namespace: ''
initial_pose:
  position: {x: 0.0, y: 0.0, z: 0.0}
  orientation: {x: 0.0, y: 0.0, z: 0.0, w: 0.0}
reference_frame: ''"
I've tried using a few things for the model_xml argument:
  • The above is the absolute path to the sdf.
  • I've tried launching it from /home/benb/Dropbox/RoboticsResearch/WAMInProgress/tp/AllInOne/Trajectory_Phonebook/ros_stuff/src/iiim_wam_description/ with the argument model_xml: 'wam.sdf'
  • I've tried using the directory name iiim_wam_description
  • I've tried using the name specified in the model.config, iiim_ros_wam
In all cases, I get the message:
success: False
status_message: GazeboRosApiPlugin SpawnModel Failure: input model_xml not SDF or URDF, or cannot be converted to Gazebo compatible format.
robot_namespace: ''
initial_pose:
success: False
It would be especially helpful if someone could give me pointers on doing this using the rospy ServiceProxy.
