Problems getting textures to load
Whenever I import a textured model from Maya into Gazebo the texture never shows up.The only time I have been successful was when I imported the duck.dae and duck.png files provided in a tutorial on Gazebo's website.
The duck example image description
However, when I use this same duck.png as a texture map on any other model I create (with the appropriate UV maps) it never shows up in Gazebo.
Here are 2 models with the textures applied in Maya. image description
image description
This is how the models appear in Gazebo image description
image description
For the submarine place holder it just rendered yellow, while the rocky terrain rendered grey.
Even when I apply a simple brown blinn shader with a bump map attached to the model it appears grey without the bump map.
Maya example image description
In Gazebo image description
Is there a texture tutorial that I'm missing?
