How do you run the rqt_runtime_monitor?
When I try to run the rqt_runtime_monitor in standalone mode as described here, the following error occurs:
$ rosrun rqt_runtime_monitor rqt_runtime_monitor
qt_gui_main() found no plugin matching "rqt_runtime_monitor"
Does anyone know how to fix this error?
I am using ROS Hydro on Ubuntu 12.04.4 64-bit desktop.
I have rqt_runtime_monitor installed and the plugin is found:
$ rospack plugins --attrib=plugin rqt_gui
rqt_runtime_monitor /opt/ros/hydro/share/rqt_runtime_monitor/plugin.xml
[SOLVED] How do you run the rqt_runtime_monitor?
