"Getting remote endpoint failed" let Gazebo-Gui crash
I'm actually trying to install ROS Indigo on a Ubuntu 14.04 machine.
Starting Gazebo ends up in most cases with (4 of 5):
Msg Waiting for masterError [Connection.cc:787] Getting remote endpoint failed
terminate called after throwing an instance of 'boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::system::system_error> >'
  what():  remote_endpoint: Transport endpoint is not connected
what always ends in:
[gazebo_gui-2] process has died [pid 30325, exit code 134, cmd /opt/ros/indigo/lib/gazebo_ros/gzclient __name:=gazebo_gui __log:=/home/alex/.ros/log/cdde1b80-e1a0-11e3-ab05-5c514ff707c4/gazebo_gui-2.log].
log file: /home/alex/.ros/log/cdde1b80-e1a0-11e3-ab05-5c514ff707c4/gazebo_gui-2*.log
Currently Gazebo 2.2.2 is used which comes via
sudo apt-get install ros-indigo-gazebo-ros
I'm starting Gazebo with
roslaunch gazebo_ros empty_world.launch
This error occurs on both nvidia and intel graphics. Thus, it seems to be independent from hardware.
Has anybody ideas what is going wrong here?
kind regards, Alex
I'm actually trying to install ROS Indigo on a an Ubuntu 14.04 machine.
kind regards, Alex
