Cannnot get joint torque while setting velocity command for joints
I use following plugin for controlling joints. https://github.com/start-jsk/rtmros_gazebo/blob/master/hrpsys_gazebo_general/src/IOBPlugin.cpp
I'm sending velocity command to joint by SetVelocity function, and trying to get joint torque by GetForce function, but return value if GetForce is always zero.
When I send torque command by SetForce function, I can get correct joint torque by SetForce.
I'm sending velocity command to joint by SetVelocity function, and trying to get joint torque by GetForce function, but return value if of GetForce is always zero.
I'm sending velocity command to joint by SetVelocity function, and trying to get joint torque by GetForce function, but return value of GetForce is always zero.
When I send torque command by SetForce function, I can get correct joint torque by SetForce.GetForce.
