Hi all
I'm trying to send a string via the Gazebo transport system. I managed to write a plugin that publishes the string I want as a GzString message. I now want to write a receiver that does something with the string. My starting point for this is this listener example.
The problem I have is that I don't know what to do with my received string in the call back function (called cb in the above example).
I have changed the call back function to accommodate for the fact that the message is a GzString as follows, but the change was essentially just a guess (replacing ConstWorldStatisticsPtr
with ConstWorldStatisticsPtr
) and I don't know if this is actually what I need to do. I can't find any documentation regarding this.
void cb(ConstWorldStatisticsPtr &_msg)
// Dump the message contents to stdout.
std::cout << _msg->DebugString();
The ->DebugString();
does not necessarily seem appropriate for a string, but I don't know what else to use or where to find documentation about this.
Can somebody help me or point me to where this is described?
Thanks,
Nick
P.S: What I'm trying to accomplish is to communicate joint angles back and forth. I would like to be able to have one message type that is able to handle a different number of joints. Right now, I just write the joint names and angle values into the string and parse them out on the receiving side. I realize that this is not very elegant but I couldn't figure out a better way. If you can offer help in doing this differently, I would also be open to suggestions.
