Downgrade from Gazebo 4
I'm trying to downgrade from Gazebo 4 to Gazebo 3 and make it work with ROS Indigo. I'm using the following steps:
sudo sh -c 'echo "deb http://packages.osrfoundation.org/gazebo/ubuntu `lsb_release -cs` main" > /etc/apt/sources.list.d/gazebo-latest.list'
wget http://packages.osrfoundation.org/gazebo.key -O - | sudo apt-key add -
sudo apt-get update
sudo apt-get install ros-$distro-gazebo4-ros-pkgs
The problem is that I get the message "E: Unable to locate package ros-indigo-gazebo3-ros-pkgs". What am I doing wrong in the steps I'm using?
sudo apt-get update
click to hide/show revision 3
Update in the situation in the attempt to downgrade.
sudo apt-get update
UPDATE: Does the package ros-indigo-gazebo3-ros-pkgs actually exist?
