Toggle visibility of a link?
Ideally I could publish a message from ROS that would set the transparency of a specified link to any value.
Would I have to write a custom plugin?
click to hide/show revision 2
Trying to get gazebojs to work
Pursuing the gazebojs approach:
I've gone through
http://gazebosim.org/tutorials?tut=gazebojs_install&cat=gazebojs
One note is that npm install installs node_modules to the current directory, I moved it to a better location and the require below is the relative path to it::
  var gazebojs = require('./npm/node_modules/gazebojs')
  var gazebo = new gazebojs.Gazebo()
  msg = { "parent_name" : "sensor_head", "name" : "sensor_head_rotation_link", "visible":false };
  gazebo.publish('gazebo.msgs.Visual', '~/Visual', msg);
But the link stays visible. Am I missing something else required to turn the visibility off? I assume leaving out all the optional fields except 'visible' in the protobuf is fine.
If I put garbage into the parent_name or name fields there are no errors. Am I using those fields incorrectly?
(I have it correct above but if the msg has a problem it mostly results in an error that crashes node like::
terminate called after throwing an instance of 'j2pb_error' what(): Unknown field: visibility Aborted (core dumped)
I've gone through
dumped)
This is using Gazebo 2.2.3
I've gone through
I've gone through
If I put garbage into the parent_name or name fields there are no errors. Am I using those fields incorrectly?incorrectly? In the World tab I see Model | sensor_head | sensor_head_rotation_link, the Property for clicking on that shows the name as sensor_head::sensor_head_rotation_link
I've gone through
If I put garbage into the parent_name or name fields there are no errors. Am I using those fields incorrectly? In the World tab I see Model | sensor_head | sensor_head_rotation_link, the Property for clicking on that shows the name as sensor_head::sensor_head_rotation_link
Pursuing the C++ Approach:
If I use the following code, launch gazebo and create a box called unit_box_1, running ./visibility unit_box_1 link still doesn't produce any visual changes.
visibility.cpp:
int main(int argn, char** argv)
  gazebo::setupClient(argn, argv);
  std::string name = "sensor_head_rotation_link";
  std::string parent_name = "sensor_head";
  if (argn >= 3)
    parent_name = argv[1];
    name = argv[2];
  gazebo::transport::NodePtr node(new gazebo::transport::Node());
  node->Init();
  // gztopic echo /gazebo/default/visual shows this
  gazebo::transport::PublisherPtr pub =
      node->Advertise<gazebo::msgs::Visual>("~/visual");
  std::cout << "waiting for connection" << std::endl;
  pub->WaitForConnection();
  double transparency = 1.0;
  bool visible = true;
  gazebo::msgs::Visual msg;
  msg.set_parent_name(parent_name);
  msg.set_name(name);
  std::cout << "parent " << parent_name << ", name " << name << std::endl;
  while (true)
    msg.set_transparency(transparency);
    msg.set_visible(visible);
    //std::cout << "transparency " << transparency << std::endl;
    pub->Publish(msg);
    visible = !visible;
    transparency = 1.0 - transparency;
    sleep(2.0);
  gazebo::shutdown();
  return 0;
I've gone through
If I use the following code, launch gazebo and create a box called unit_box_1, running ./visibility unit_box_1 link link still doesn't produce any visual changes.
visibility.cpp:
  if (argn >= 3)
    name = argv[2];
  node->Init();
  msg.set_name(name);
  while (true)
    pub->Publish(msg);
    visible = !visible;
    sleep(2.0);
  gazebo::shutdown();
  return 0;
