Importing cad model in gazebo
Hi ,
I want to import cad model in gazebo3. Can anyone suggest how can I do that? Any help would highly be appreciated.Thanks!
Hi ,
I want to import cad model models in gazebo3. gazebo3 to create the environment. Can anyone suggest how can I do that? Is there any tutorial related to this? Any help would highly be appreciated.Thanks!
Hi ,
I want to import cad models in gazebo3 to create the environment. Can anyone suggest how can I do that? Is there any tutorial related to this? Any help would highly be appreciated.Thanks!this?cad model stored as .stl format developed in solidworks tool into gazebo 2.2 version. I used blender to convert it into .dae file. when I import it into gazebo it automatically starts moving without applying any forces or velocity and starts falling down . Then I convert it first to .obj file and then .dae but then also it behaves the same. Can anyone suggest what is wrong? here I am attaching my .dae file . I saved it as .sdf because it wasn't accepting the .dae format while attaching. The attached file is .obj to .dae converted file. Thanks! objTO dae.sdf
Hi ,
I want to import cad models in gazebo3 to create the environment. Can anyone suggest how can I do that? Is there any tutorial related to this?cad model stored as .stl format developed in solidworks tool into gazebo 2.2 version. I used blender to convert it into .dae file. when I import it into gazebo it automatically starts moving without applying any forces or velocity and starts falling down . Then I convert it first to .obj file and then .dae but then also it behaves the same. Can anyone suggest what is wrong? here I am attaching my .dae file . I saved it as .sdf because it wasn't accepting the .dae format while attaching. The attached file is .obj to .dae converted file. Thanks! objTO dae.sdf
Here is the sdf for above mesh.
<sdf version="1.4">
<model name="robot">
<link name="link1">
    <mass>10000.0</mass>
      <ixx>140</ixx>
      <ixy>0.0</ixy>
      <iyy>550</iyy>
      <ixz>0.0</ixz>
      <iyz>0.0</iyz>
      <izz>550</izz>
    <!-- rotate mesh to get to X-forward -->
    <pose>0 0 0 0 0 -1.570796</pose>
      <mesh>
    <scale>20 20 20</scale>
        <uri>model://robot/meshes/untitled3.dae</uri>
      </mesh>
  <mesh>
        <scale>100 100 100</scale>
      </mesh>
Hi ,
I want to import cad models in gazebo3 to create the environment. Can anyone suggest how can I do that? Is there any tutorial related to this?cad this?I want to import cad model stored as .stl format developed in solidworks tool into gazebo 2.2 version. I used blender to convert it into .dae file. when I import it into gazebo it automatically starts moving without applying any forces or velocity and starts falling down . Then I convert it first to .obj file and then .dae but then also it behaves the same. Can anyone suggest what is wrong? here I am attaching my .dae file . I saved it as .sdf because it wasn't accepting the .dae format while attaching. The attached file is .obj to .dae converted file. Thanks! objTO dae.sdf
<sdf version="1.4">
<link name="link1">
      <ixx>140</ixx>
      <ixy>0.0</ixy>
      <iyy>550</iyy>
      <ixz>0.0</ixz>
      <iyz>0.0</iyz>
      <izz>550</izz>
      <mesh>
      </mesh>
  <mesh>
      </mesh>
Hi ,
I want to import cad models in gazebo3 to create the environment. Can anyone suggest how can I do that? Is there any tutorial related to this?I want to import cad model stored as .stl format developed in solidworks tool into gazebo 2.2 version. I used blender to convert it into .dae file. when I import it into gazebo it automatically starts moving without applying any forces or velocity and starts falling down . Then I convert it first to .obj file and then .dae but then also it behaves the same. Can anyone suggest what is wrong? here I am attaching my .dae file . I saved it as .sdf because it wasn't accepting the .dae format while attaching. The attached file is .obj to .dae converted file. Thanks! objTO dae.sdf
<sdf version="1.4">
<link name="link1">
 <sdf version="1.4">
   <link name="link1">
       <ixx>140</ixx>
       <ixy>0.0</ixy>
       <iyy>550</iyy>
       <ixz>0.0</ixz>
       <iyz>0.0</iyz>
       <izz>550</izz>
       <mesh>
       </mesh>
   <mesh>
       </mesh>
