How to use UserCamera->ViewController()?
I am running gazebo2.2.
I want to control UserCam ,and looked up in API doc(http://osrf-distributions.s3.amazonaws.com/gazebo/api/2.2.1/classgazebo_1_1rendering_1_1UserCamera.html#a7148635d156d63c3e163bf1c28bb547e)
I found three function as following:
EnableViewController(TRUE); SetFocalPoint(math::Vector3(0,0,0.1)); SetViewController("orbit",math::Vector3(0,1,0.5));
So , I imaged that my userCam would orbit the point(0,0,0.1)
but, It turned out nothing happened!
Did I miss some steps?
Thank you~!
if it is possible, can you check my code?
Here is my code:
include <gazebo-2.0 gazebo="" math="" pose.hh="">
include <boost bind.hpp="">
include <gazebo gazebo.hh="">
include <gazebo physics="" physics.hh="">
include <gazebo common="" common.hh="">
include <gazebo math="" matrix4.hh="">
include <stdio.h>
include <cmath>
include <stdlib.h>
include <time.h>
include <iostream>
include <ostream>
include "gazebo/transport/transport.hh"
include "gazebo/msgs/msgs.hh"
include "gazebo/msgs/vector3d.pb.h"
include <gazebo rendering="" rendering.hh="">
include <gazebo gui="" gui.hh="">
#include <signal.h>
using namespace std; using namespace gazebo;
class SystemGUI : public SystemPlugin { public:~SystemGUI() { cout<<"in destructor"<<endl; }<="" p="">
public: void Load(int /_argc/, char * /_argv*/) { this->connections.push_back(event::Events::ConnectPreRender(boost::bind(&SystemGUI::Update, this))); cout<<"Load()"<<endl; }="" private:="" void="" update()="" {<="" p="">
if (!this->userCam)
    // Get a pointer to the active user camera
    this->userCam = gui::get_active_camera();
    cout<<userCam->GetName()<<endl;
    userCam->SetAspectRatio (3);
math::Vector3(0, pitch, yaw)));
userCam->EnableViewController(TRUE);
userCam->SetFocalPoint(math::Vector3(0,0,0.1));
userCam->SetViewController("fps",math::Vector3(0,1,0.5));
scene = rendering::get_scene();
if (!scene || !scene->GetInitialized())
return;
/// Pointer the user camera. private: rendering::UserCameraPtr userCam; rendering::ScenePtr scene; /// All the event connections. private: std::vector<event::connectionptr> connections;
GZ_REGISTER_SYSTEM_PLUGIN(SystemGUI);
Thank you~!
Here is my code:
include <stdio.h>
include <cmath>
include <stdlib.h>
include <time.h>
include <iostream>
include <ostream>
#include <signal.h>
if (!this->userCam)
return;
Thank you~!
Here is my code:
include <stdio.h>
include <cmath>
include <stdlib.h>
include <time.h>
include <iostream>
include <ostream>
if (!this->userCam)
return;
Thank you~!
Here is my code:
include <stdio.h>
include <cmath>
include <stdlib.h>
include <time.h>
include <iostream>
include <ostream>
if (!this->userCam)
return;
GZ_REGISTER_SYSTEM_PLUGIN(SystemGUI);code: http://pastebin.com/QvniRiKK
Thank you~!
Here is my code: http://pastebin.com/QvniRiKKhttp://pastebin.com/emWnSf00
