Inaccurate Laser scan from the Hokuyo sensor Gazebo
Hi all,
I have been working on setting up the simulation environment in Gazebo and I have a simple mobile base with the hokuyo sensor on top of it. The laser scan coming out of it seems inaccurate.image description
I know I am doing some thing silly but I am not able to figure it out. I have attached the necessary code for the Hokuyo sensor. Please let me know if you need anything else from my side.
drsim.xacro <link name="base_laser_link"> <collision> <origin xyz="0 0 0" rpy="0 0 0"/> <geometry> <box size="0.1 0.1 0.1"/> </geometry> </collision>
    <visual>
            <mesh filename="package://drsim_control/meshes/hokuyo.dae"/>
        <mass value="1e-5" />
        <inertia ixx="1e-6" ixy="0" ixz="0" iyy="1e-6" iyz="0" izz="1e-6" />
drsim.gazebo
<gazebo reference="base_laser_link"> <sensor type="gpu_ray" name="head_hokuyo_sensor"> <pose>0 0 0 0 0 0</pose> <visualize>true</visualize> <update_rate>40</update_rate> <ray> <scan> <horizontal> <samples>720</samples> <resolution>1</resolution> <min_angle>-1.570796</min_angle> <max_angle>1.570796</max_angle> </horizontal> <vertical> <samples>1</samples> <resolution>1</resolution> <min_angle>0</min_angle> <max_angle>0</max_angle> </vertical> </scan> <range> <min>0.10</min> <max>30.0</max> <resolution>0.01</resolution> </range> <noise> <type>gaussian</type> <mean>0.0</mean> <stddev>0.01</stddev> </noise> </ray>
      <plugin name="gazebo_ros_head_hokuyo_controller" filename="libgazebo_ros_gpu_laser.so">
        <topicName>/base_scan</topicName>
        <frameName>base_laser_link</frameName>
Any help will be appreciated.
Thanks!
Naman
Hi all,
drsim.xacro drsim.xacro
    <visual>
drsim.gazebo
Thanks!
Naman
Hi all,
drsim.xacro
<!-- Hokuyo Laser -->
        <collision>
        <visual>
drsim.gazebo
drsim.gazebo <!-- hokuyo --> <gazebo reference="base_laser_link"> <sensor type="gpu_ray" name="head_hokuyo_sensor"> <pose>0 0 0 0 0 0</pose> <visualize>true</visualize> <update_rate>40</update_rate> <ray> <scan> <horizontal> <samples>720</samples> <resolution>1</resolution> <min_angle>-1.570796</min_angle> <max_angle>1.570796</max_angle> </horizontal> <vertical> <samples>1</samples> <resolution>1</resolution> <min_angle>0</min_angle> <max_angle>0</max_angle> </vertical> </scan> <range> <min>0.10</min> <max>30.0</max> <resolution>0.01</resolution> </range> <noise> <type>gaussian</type> <mean>0.0</mean> <stddev>0.01</stddev> </noise> </ray>
</ray>
Thanks!
Naman
Hi all,
drsim.xacro
        <collision>
        <visual>
drsim.gazebo
 <!-- hokuyo -->
            <ray>
                <scan>
                    <horizontal>
                    </horizontal>
                    <vertical>
                    </vertical>
                </scan>
                <range>
                    <min>0.10</min>
                    <max>30.0</max>
                </range>
                <noise>
                    <mean>0.0</mean>
                </noise>
          </ray>
Update: I have attached the image after View->Collisions image description
Thanks!
Naman
Hi all,
drsim.xacro
        <collision>
        <visual>
drsim.gazebo
 <!-- hokuyo -->
            <ray>
                <scan>
                    <horizontal>
                    </horizontal>
                    <vertical>
                    </vertical>
                </scan>
                <range>
                    <min>0.10</min>
                    <max>30.0</max>
                </range>
                <noise>
                    <mean>0.0</mean>
                </noise>
          </ray>
Update 2: It turns out that even if I have only the sensor (no mobile robot), I get the same inaccurate laser scan. So, I think the type of sensor is wrong because when I change the type of sensor to "ray" from "gpu_ray" and plugin to libRayPlugin.so from libgazebo_ros_gpu_laser.so, I get the accurate laser scan as shown: image description
But I cant use the new plugin if I want to interface gazebo with ros and get the laser scan data on a ros topic (For example /base_scan). Does anyone have any insights into this?
Thanks!
Naman
Hi all,
drsim.xacro
        <collision>
        <visual>
drsim.gazebo
 <!-- hokuyo -->
            <ray>
                <scan>
                    <horizontal>
                    </horizontal>
                    <vertical>
                    </vertical>
                </scan>
                <range>
                    <min>0.10</min>
                    <max>30.0</max>
                </range>
                <noise>
                    <mean>0.0</mean>
                </noise>
          </ray>
Update 2: It turns out that even if I have only the sensor (no mobile robot), I get the same inaccurate laser scan. So, I think the type of sensor is wrong because when I change the type of sensor to "ray" from "gpu_ray" and plugin to libRayPlugin.so from libgazebo_ros_gpu_laser.so, I get the accurate laser scan as shown: shown:
image description
Thanks!
Naman
