I'm attempting to subscribe to a sensor's data from a model plugin. Simplified, my model plugin code looks like:
#include <boost/bind.hpp>
#include <gazebo/gazebo.hh>
#include <iostream>
namespace gazebo
class SensorRead : public ModelPlugin
this->model = _parent;
std::cout << "Plugin loaded" << std::endl;
std::string topicName = "~/my_model/my_link/my_sensor/imu";
transport::NodePtr node(new transport::Node());
node->Init("default");
node->Subscribe(topicName, &SensorRead::OnUpdate, this);
public: void OnUpdate(ConstIMUPtr & /*msg*/)
std::cout << "An update!" << std::endl;
// Pointer to the model
GZ_REGISTER_MODEL_PLUGIN(SensorRead)
The world code I've tested it with is equally simple, just a box, with a link, with an IMU sensor with an update rate of 5.
When I open a command prompt and do
gz topic -e "~/my_model/my_link/my_sensor/imu"
it starts spitting out IMU data 5 times per second as is to be expected. However, upon loading the model with the plugin, it outputs "Plugin loaded", and then... nothing. I've tried a wide array of namespaces, and have even verified in code that the topic name I use exists through TopicManager::FindPublication()
. It seems like the topic is there, the events are there, but my model plugin is not allowed to have them.
I've no idea what I'm doing wrong, is what I'm trying to do not meant to be possible?
