No skyx texture on Gzweb
While on Gazebo SkyX works as expected, it doesn't seem so on Gzweb for me. We set it after sunset to show the starry sky on moon, but the sky is all blacked out, no stars, Sun and the earth (as we customized).
no starry sky
I found that the files in skyx folders in Gazebo and Gzweb are slightly different, but copying the one from Gazebo didn't solve the issue.
Using Gazebo (2.2.5), Ubuntu 14.04, Gzweb 1.2.0 with the following commit.
changeset:   840:a166e0734e7d
tag:         tip
date:        Fri Jan 30 09:44:59 2015 -0800
no starry sky
I found that the files in skyx folders in Gazebo and Gzweb are slightly different, but copying replacing Gzweb's dir (gzweb/http/client/assets/media/skyx) with the one from Gazebo didn't solve the issue.
tag:         tip
no starry sky
I found that the files in skyx folders in Gazebo and Gzweb are slightly different, but replacing Gzweb's dir (gzweb/http/client/assets/media/skyx) with the one from Gazebo didn't solve the issue.
tag:         tip
(UPDATE) In ROS level models seem to be present:
$ rostopic echo /gazebo/model_states
name: ['apollo15_landing_site_1000x1000', 'tetris']
pose:
    position:
      x: 0.0
      y: 0.0
      z: 0.0
    orientation:
      x: 0.0
      y: 0.0
      z: 0.0
      w: 1.0
    position:
      x: 58.9562610985
      y: 20.1524164004
      z: 0.150904308409
    orientation:
      x: -0.0873401808555
      y: -0.0876231757086
      z: -0.696680910616
      w: 0.706632564117
twist:
    linear:
      x: 0.0
      y: 0.0
      z: 0.0
    angular:
      x: 0.0
      y: 0.0
      z: 0.0
    linear:
      x: -2.07776276178e-06
      y: 5.84743454133e-05
      z: -0.000877068884443
    angular:
      x: 0.000107081413827
      y: 1.7612055967e-05
      z: -6.53299105319e-06
no starry sky
tag:         tip
pose:
    position:
      x: 0.0
      y: 0.0
      z: 0.0
    orientation:
      x: 0.0
      y: 0.0
      z: 0.0
      w: 1.0
    position:
      x: 58.9562610985
      y: 20.1524164004
      z: 0.150904308409
    orientation:
      x: -0.0873401808555
      y: -0.0876231757086
      z: -0.696680910616
      w: 0.706632564117
twist:
    linear:
      x: 0.0
      y: 0.0
      z: 0.0
    angular:
      x: 0.0
      y: 0.0
      z: 0.0
    linear:
    angular:
      y: 1.7612055967e-05
