Should URDF in Gazebo tutorials be replaced with SDF?
Migrated from here.
In the QA thread "SDF vs URDF what should one use?" (on answers.gazebosim.org), URDF is not recommended on gazebo in favor of SDF. But from the answer in this thread, sounds like URDF will still be supported on gazebo. Can we keep the tutorial using URDF?
A couple of comments there:
It would be better to have one standard (and also use the new version
of Gazebo in ROS), would prevent a lot of problems. But URDF is also
used in RVIZ which doesn't care about the extra proporties like
friction. @davinci
2nd:
I'm in favour. I'm new and the learning curve is steep when I need to
pull bits of advice off of gazebosim (usually SDF) and ros answers
(URDF) and figure out what's valid where and in which version of Gazebo.
@Benjamin Blumer
Benjamin Blumer
Migrated from hereROS' community's website.
friction. @davinci
2nd:
@Benjamin Blumer
Benjamin Blumer
Migrated from ROS' community's website.
friction. @davinci
2nd:
@Benjamin Blumer
Benjamin Blumer
