I'm trying to follow this tutorial to build a myrobot_gazebo package for Indigo with Gazebo 5.
I create my package with:
catkin_create_pkg myrobot_gazebo gazebo_msgs gazebo_plugins gazebo_ros gazebo_ros_control cheetahbot_description
then, when I try to update my dependencies with:
rosdep update
rosdep install --from-paths . --ignore-src --rosdistro indigo
I get the error:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
ros-indigo-gazebo-ros-control : Depends: gazebo2 but it is not going to be installed
Depends: libsdformat1 but it is not going to be installed
Depends: ros-indigo-gazebo-ros but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
ERROR: the following rosdeps failed to install
apt: command [sudo -H apt-get install ros-indigo-gazebo-ros-control] failed
I'm assuming this is because I'm using Indigo, which is built for the old Gazebo 2, while I'm using Gazebo 5. How do I fix this?
I saw this page in the Gazebo tutorials that make a brief mention to this problem:
I need to use gazebo4/gazebo5 and ROS Indigo, what can I do?
Warning!: Using this option, you won't be able to use any ROS Indigo package related to Gazebo from ROS deb repository. The way to go is to build them from source. Thanks to catkin workspaces this is quite easy to do.
If you need some features only present in version 4.x or 5.x of Gazebo, there is a way of installing gazebo4 or gazebo5 and ROS Indigo. Please follow the instructions about how to use ROS with gazebo4 package or gazebo5 which are in this same docuement.
However, I can't find any clear instructions about how to use ROS with gazebo5 in that document. They mention installing the ros-indigo-gazebo5-ros-pkgs package, but I already have that installed.
A similar question, "how to use Gazebo 3.* with Indigo is mentioned, and it links to here, but that's just a landing page and there are no instructions on how to make it work with Indigo.
