Moving a ROS robot in Gazebo, are plugins necessary or can I use topic/node method instead?
Hi all, I'm really newbye in Gazebo and I tried in last days to read everything I could find to use Gazebo for my simulated robot.
So far so good..I've a small robot which moves really good under RViz and now I'm interested to simulate it in Gazebo. Since the ROS Node is going to simulate the robot's dynamic I want at first move it under Gazebo. Something similar I 've found in this question. But I'm still a little bit confused about Plugins in Gazebo. For my understanding one could move the robot just publishing from ROS information about velocity and position on the following two topics:
/gazebo/set_link_state
/gazebo/set_model_state
So...now...why should I need a plugin? What's the purpose for?
Is the way (publishing on these topics) right? Or one should create a plugin of the robot to get simulated in Gazebo?
Many thanks in advance Regards
