Installing ROS Jade with Gazebo 5.0.1
While following the tutorial for installing Gazebo with ROS, I reach a point where there is no option for ROS Jade. The current text looks like:
sudo apt-get install ros-indigo-gazebo-ros-pkgs ros-indigo-gazebo-ros-control
However when I try:
sudo apt-get install ros-jade-gazebo-ros-pkgs ros-jade-gazebo-ros-control
it appears that the latter package ros-jade-gazebo-ros-control isn't available. Can I / how can I proceed installing ROS J with Gazebo 5.0.1?
click to hide/show revision 2
Provided slightly more information
However when I try:
For slightly more information I've installed Gazebo 5.0.1, and tested to know it works. I've installed ROS Jade via ros-jade-desktop-full , and I've done some limited testing to see that it works. All this is on Ubuntu 14.04
