gazebo 5.0 installation problem
Hello, I am trying to upgrade from ros indigo to ros jade. I followed the following procedure
sudo apt-get get remove ros-indigo-desktop-full
then
sudo apt-get get install ros-jade-desktop-full
However, when I am trying to launch a simulation with gazebo I obtain the following error
/opt/ros/jade/lib/gazebo_ros/gzserver: 22: .: Can't open /share/gazebo//setup.sh
/opt/ros/jade/lib/gazebo_ros/gzclient: 17: .: Can't open /share/gazebo//setup.sh
[gazebo-2] process has died [pid 5171, exit code 2, cmd /opt/ros/jade/lib/gazebo_ros/gzserver -e ode /home/mago/Projects/2015a_Nicastro_HeterogeneousMultirobot/src/uav/worlds/vtol.world __name:=gazebo __log:=/home/mago/.ros/log/0b588c00-6078-11e5-b34f-f04da268d7ae/gazebo-2.log]. log file: /home/mago/.ros/log/0b588c00-6078-11e5-b34f-f04da268d7ae/gazebo-2*.log
Apparently it can't find the file /share/gazebo//setup.sh
I noticed the double slash, therefore I tried to search the setup.sh file manually. However, the command
ls /usr/share/ | grep gazebo
gives
gazebo-3.0
gazebo-5.0
Moreover, in the "gazebo-5.0" folder there is no file "setup.sh"
I think something went wrong during the installation, I tried to remove everything and reinstall but without success. Can anyone help me?
click to hide/show revision 2
added a step to solve the issue
then
gives
gazebo-3.0
gazebo-5.0
EDIT: I tried the workaround described here, but apparently I have libgazebo5-dev already installed.
