I am trying to send model state information to gazebo for my robot, and control it using a teleop_twist_keyboard. The model state is sent and received fine, but then the robot starts rubberbanding around on the axis where I changed its position (I am sending absolute xyz/orientation, not velocity commands from the teleop keyboard). I noticed that if I either disable physics under the Physics tab on the gui, or set Models/MyRobot/link1/kinematic true, also through the gui, everything behaves much much better.
The problem is, I can't find a way to change either of those options through the command line or through ROS. The options are neither in the physics properties message nor the link properties message, and I haven't seen any other way to change them other than the gui.
Pausing and unpausing physics does not work, since that turns off the simulation timer altogether which means model state positions aren't updated, nor are laser scans. If I try to set my model to static, then my laser link stops updating rayscans, which is not helpful. Doing <kinematic>true</kinematic> on my .gazebo for the .urdf did nothing at all.
Is there a way to either disable physics (but keep the simulation running) or make my link/robot kinematic through command line arguments or through ROS service calls/messages? Preferably the disabling physics one, though, since it's running on a VM and disabling physics gives a massive speed boost.
ROS Version: Jade Gazebo Version: 5.0
